Home › Forums › Products › Stompboxes › H9 – mode to use right footswitch to cue presets
- This topic has 5 replies, 2 voices, and was last updated 2 years, 8 months ago by
joecozzi
Eventide Staff.
April 10, 2023 at 12:15 pm #170344
I have recently acquired an H9. Somehow the pedal got into a mode that prevents me from using the right footswitch to cue presets. I have read the manual and it haven’t been able to find answer to what is probably a simple question. How do I return the H9 to the mode that allows me to use the right footswitch to cue presets?
April 10, 2023 at 12:38 pm #170345
Hold the right footswitch down for 2 seconds. Doing so switches the pedal from tap tempo mode to preset search mode and back.
April 10, 2023 at 2:14 pm #170350
I held the right footswitch down for 2 seconds but it did not switch between tap tempo mode and preset search mode. Instead, the display said BLUE and then the PIN was displayed and the Active and Tap lights started flashing. Can you help?
April 10, 2023 at 2:18 pm #170351
What you are describing should only happen if you press the Hotswitch button and right footswitch simultaneously. It sounds like you’re in the system settings. To get out of it, just press Hotswitch button and right ftsw for two seconds again.
April 10, 2023 at 2:41 pm #170352
When I press Hotswitch button and right ftsw for two seconds, the display says HOT and then switches to HOT+. Unfortunately, that didn’t work either. What should I try next?
April 10, 2023 at 2:47 pm #170353
None of this sounds like normal operation. Do you have any custom presets? If so, you can back up your presets to a list on H9 Control and conduct a factory reset. This will erase everything including presets and system settings. Afterwards, you can load your list back in.
To restore Factory Presets and all System settings, power up the H9 while simultaneously pressing the Right Footswitch and the big Knob until [INITIA] is displayed.
If you still have problems after this, please contact support@eventide.com.
