H9 no signal
Home Forums Products Stompboxes H9 no signal
Viewing 3 reply threads
    • #112196
      keef88
      Hi
      I have a problem, since a few days I can not use. Everything is connected properly. After connecting to the power supply is not lit green LED signal and the signal passes through H9 When you power up your computer is disconnected signal passes through H9
      Reset the device does not help.
    • #127240
      gkellum
      You should probably send an email to support@eventide.com about this as your unit might require repair.  So, previously the H9 connected to the computer fine, and now, it doesn't?  And how have you been powering the unit?
    • #127241
      keef88
      thanks for the reply
      I have already written to support
      everything works, is to communicate with the PC but no signal
      the power supply is the original
    • #137867
      gkellum
      One mistake people sometimes make is to connect a single cable into input 2 instead of input 1. That's one thing you could check.
