New owner
I see that most of the reverb algorithms are stereo
I'm running the h9 at the end of my pedalboard going into the amp. Channel one on a Rivera Sedona is TRS for 2 input signals. I have a second clean channel.
For a Hall reverb, would it sound better:
1-In mono unbalanced
2-Using a Y cable with 2 TS to TRS connecting to both outputs running TRS into the front of the amp
3-Is either output TRS
4-Is there a better algorithm for a Hall reverb in mono
5-Run into both channels of the amp
Thank You
Tom
