H9 Output Volume Midi Help
Home Forums Products Stompboxes H9 Output Volume Midi Help
    • #143553
      In system mode, go to MIDI/RCV.CTL/OSW.
    • #113502
      Joey
      Is the a away to use a CC command to set the Output Volume level on an H9. I don’t want to use my expression pedal to adjust it. I’d rather have it control other parameters (which I’ve already set up). I’d just like to be be able to tweak the Output Volume (set is at 2 dB or -3 dB etc.) when I send a preset fron my controller. I don’t want to change and save the level on the H9’s preset, as I use the same H9 presets for different presets on my controller.
      I’m using a RJM Mastermind PBC, and I have two H9s.
      Seems to me this shouldn’t be difficult but I can’t seem to figure it out.
      Thanks,
      Joe
