H9 pitch slowly going up, how to?
Home › Forums › Products › Stompboxes › H9 pitch slowly going up, how to?
Viewing 3 reply threads
    • #114590
      Hello, I’m looking for a pitch effect like the one you can heard in this song at 3.50
      https://m.youtube.com/watch?v=ZSznpyG9CHY
      It sound like a pitch shifter that changes very slowly.
      Can you help me, please?
    • #148352
      camn
        Using PitchFlex and an expression pedal you can go any speed. Without….you can set the performance switch to a 2 second maximum gliss….which I think is enough.
      • #149840
        entreat69
          i’d Highly recommend that you check out the PitchFuzz algorithm:
          it’s a combination of a pretty wide range of Dirty Fuzz tones together with up to 3 pitches where if you’re playing you can assign one for drop Octave while still assign the desired pitch of the other 2 and assign any or all of them to Exp pedal.
        • #149844
          mistercharlie
            H910-H949 will slowly increase pitch. This one will do it forever (hopefully the image will upload).
