H9 PitchFlex delay using expression pedal
Home › Forums › Products › Stompboxes › H9 PitchFlex delay using expression pedal
    • #115635
      sheldonheardmusic
        Hey guys,
        I’ve recently purchased the PitchFlex for my H9 hoping to use it as a “Whammy” but I’ve noticed when I rock my expression pedal too quickly it skips and gets choppy. Its not a smoth quick climb up or down. I am using a Mission / Pigtronix dual expression pedal plugged into a Voodoo Lab Ground Control Pro. The GCP then heads into the Midi Solutions Quadra Thru then off to the H9. Could the midi route be causing this lag? I dont notice it skipping on other presets but really when I try the Pitchflex. Is there a setting I am overlooking or any ideas? Reason for the midi expression is that the H9 is in a rack.
        Much Thanks!
        S.
      • #153339
        camn
