H9 Power Supply Solutions
Home › Forums › Products › Stompboxes › H9 Power Supply Solutions
Viewing 3 reply threads
    • #111517
      I've had problems powering up my H9 at outdoor gigs using the factory wallwart. It never seems to be an issue inside. I have a Rifftone Performer Power Block which powers all my other pedals. It is center negative and does not have a 500 mA out.
      From searching the forums I've learned some of the stompboxes will operate at 12V with lower amp ratings. The Rifftone has a 12V 250 mA out. If I used a polarity adapter will this be adequate to power the unit? Am I in any danger of damaging it if I try it?
      The Rifftone also has two 9V 250 mA outs. If I bridge these using a VooDoo Labs current doubler (Y connector) and reverse the polarity, will that work?  I don't know much about electronics. My concern is if using a Y will double the voltage as well as the amperage and damage the unit.
      Any illumination on the topic is appreciated.
    • #125671
      The H9 will run at 12V but needs 400mA, 250mA won't be enough. Using a current doubler should do the job. If it's doubling the current, the voltage won't be affected.
    • #125674
      Awesome. Thanks for the input. It sure beats having to but a power conditioner and an extra rack.
    • #126258
      cvldash
        voodoo lab iso-5 has 400mA.
        What i must to use? 9v or 12v?
