H9 power switch
Home Forums Products Stompboxes H9 power switch
    • #114702
      romax
      hi all i just got the h9, what a amazing piece of machinery and chip making!
      quick question, whats the best way (in the long run) to turn off & on the H9?
      unplugging from the small tip from the back or removing the big plug (not so convenient in my case)?
    • #149014
      Best to remove the big plug, so as to reduce electric stress.
      But, probably does not matter. You can also leave it on for a long time.
      My suggestion is to power all your gear from the same place, so you can turn it off with a single switch. This also reduces the risk of ground loops and encourages common grounding which is safer.
      • #149029
        romax
        thanks for your reply, i have all my studio equipment on one switch as you said, i might not use the h9 everyday (i should i know) so i guess i leave it always on, since you stated thats not a prob.
        btw..brilliant machine you guys developed, hats off and i (not my wife) cant wait for the H9000 release!
