H9 Preset number error
Home › Forums › Products › Stompboxes › H9 Preset number error
Viewing 3 reply threads
    • #115986
      mikeller
        I have a preset list oddity
        My preset in question has 12 presets with 13-99 turned off.   When I cycle thru them I get  1 2 3 4 5 5 7 9 10 11 12  (2 fives, no six, no 8).   The app is reporting 1-12 however the list has 14 with two blanks at the end that cannont be deleted and has to be set with the range of 1-14 (again it says 12).  If I make it 1-12 then it discards the last preset.
        So I created a brand new set list with the same presets and guess what – same problem
        When I save preset list to the pedal and watch has things happens it almost looks like the first preset is going to a space 0 ?????
        I have tried to reset the pedal,  update the firmware all to no avail.
        Has anyone experienced this???
        Thank you
      • #155253
        bohan
          Could you take a screenshot of your preset list page? Like the attached one.
        • #155254
          mikeller
            Note – two blank presets – but if you look at the top it says 1-12  (not 14).   The preset list is defined as 1-14 because if I make it 1-12 as it cuts off the last preset
            Now when I cycle thru this on the H9, it goes 1 2 3 4 5 5 7 9 etc….
          • #155263
              Something similar popped up a few years back.  Might be useful (posts #8 through #13 here):
              https://www.eventideaudio.com/comment/26002#comment-26002
            • #155256
              bohan
                OK. Could you export your preset list and attach it here?
              • #155265
                mikeller
                  Thank you!!!  YES,  thats exactly when it went south – I tried to rename a few presets.   Forgot that.
