Home › Forums › Products › Stompboxes › H9 Presets and Midi values
July 12, 2016 at 1:23 pm #113561dazzaParticipant
Hi
i’m new to this midi game and trying to load up some presets by an mornstar fx MC6 midi controller.
i’m trying to track down the actual number of a preset? how can i find this number?.. eg a preset is listed as number 2 on my unit? but when i assign PC#2 to my midi controller i will get another number preset.
what am i missing?
Thanks
Daz
July 12, 2016 at 2:31 pm #143808dazza wrote:
Hi
i'm new to this midi game and trying to load up some presets by an mornstar fx MC6 midi controller.
i'm trying to track down the actual number of a preset? how can i find this number?.. eg a preset is listed as number 2 on my unit? but when i assign PC#2 to my midi controller i will get another number preset.
what am i missing?
Thanks
Daz
There is a thing called a MIDI Map that tells the H9 what preset to load. Look in the UM under MIDI/RCV.MAP
July 13, 2016 at 9:02 am #143813dazzaParticipant
yeah – its not the most helpful instruction. the strymon timeline was easier in this regard. is there a way to see the preset number from within the h9 control?
Yes, if you click on the Pedal button in the bottom menubar of H9 Control, go to MIDI Settings, and to Program Change Receive Map, that is the aforementioned map. The default program change receive map is sequential. Did you buy your H9 from someone? If you want to reset it's system settings to restore its program change receive map to its default state, you can turn it off and the turn it on witht the right footswitch and the HotKnob button pressed (the button in the upper left hand corner of the H9).
