h9 presets output volume
Home Forums Products Stompboxes h9 presets output volume
    • #114015
      Rorschach82
      can I adjust the volume output of a preset from the pedal itself without using the app?
    • #145772
      Yes. See "Setting Output Level" UM p.13.
      Pretty much anything you can do with the app, you can do on the pedal.
    • #147852
      geezbill
      that part of the manual is for Global output lvl. How to change the level on the preset via the unit?
      • #147853
        You may be mistaken. Look for OUTLVL. The global levels are called "Input and Output Swell."
        The UM says "Output level is a bit of a different story. It is sometimes desirable to adjust the level of a given Effect/Preset. For example, an effect like Rotary can have wide swells of amplitude and, depending on a given Preset’s parameter settings, you may find it too quiet or too loud. This is a consequence of the effect and not a question of level matching to best fit in a setup. For this reason, Output Level settings can be tweaked and saved with the Preset."
