H9 presets transferrable to H90?
Home Forums Products Stompboxes H9 presets transferrable to H90?
Viewing 3 reply threads
    • #167434
      uncuredporkpie
      Hi there,
      am I able to upload my h9 presets to the h90 through the editor software at all, or do I need to manually set them up from scratch?
      also..how does the h90 editor connect to the pedal? Is bluetooth still an option?
      Cheers!
      Edd
    • #167435
      Yes, you can import H9 presets using H90 Control. Connecting to H90 Control is currently limited to USB only, but we’ll be adding bluetooth support in a future update.
      • #167438
        brockstar
        I thought that was still being addressed? I can’t make .h9z files load in h90 control, only .tide files.
      • #167447
        If a user exports preset files from H9 Control, they will be .tide files and able to import with H90 Control. This issue you are having only relates to downloading H9 presets from the preset sharing page.
    • #167436
      uncuredporkpie
      Thanks for the info!
    • #183517
      jjbs58
      Hello
      I just purchased an H90 as well as an H9. I would like to control the H9 with the H90 control app on my ipad.  Is this possible? and if so would I just use patch cords (stereo to stereo) the h9 into the H90 and then add it to the H90 control app?  Or would I have to route it in like a non-eventide pedal…?  thanx      –  looking for a You Tube vide demonstrating this  thanx again
      • #183540
        The H9 cannot be used with H90 Control. You’ll need to use H90 Control with the H90, and H9 Control with the H9.
        There are many ways the two pedals can be routed together, this will depend on what you are trying to achieve.
        I would suggest watching our YouTube tutorials here: https://www.eventideaudio.com/forums/topic/h90-video-tutorials/
