H9 promo plugin bundle.
Home Forums Products Plug-Ins H9 promo plugin bundle.
Viewing 13 reply threads
    • #116202
      joeydego
        I initially started out with an H9 harmonizer and upgraded to a max when it was new (years ago now). Seems my account still shows its a harmonizer and I can’t take advantage of the promotional bundle.
      • #156345
        tlongabaugh
          Hi-
          You could try this link and see if it gives you the "Claim Your License" option: https://www.eventideaudio.com/store/free-h9-plugin-series-bundle.
          If not, then your Max was probably never registered properly. You should email support@eventide.com with your Eventide account name andH9 serial number, and we can get you sorted out there.
          -Tom
        • #156347
          Fender17
            I received Eventide email with Bundle Offer. Thanks a lot! It is great surprise and wonderfull gift.
            One question. Are plugins NKS ready or not? Only Blackhole works as NKS, but I alrady had it installed before. The Bundle instalator has an option to install NKS files, so I expected it is NKS….
            Have I installed it wrongly, or there is not any NKS support, or there is only “partial” NKS support?
            Would be great if NKS would worked.
          • #156361
            Have a max and a. Core. Registered this morning for the freebie bundle (thanks eventide!).
            I registered for an Ilok account and 11 products show there but I do not see any serial numbers or licence keys, are they emailed separately and if so how long does that take?
          • #156365
            Ah no not done that, wasn’t aware I had to drag them anywhere. Will do so later today and report back. I new this would be user error. Many thanks.
          • #156385
            joeydego
              Very grateful for Patrick for getting this sorted out for me, thanks man!!!
            • #156390
              Fender17
                Thanks Tom for clarifying NKS support backround.
                So, I will have to do it myself, or ask someone to do it for me. For those that are not done yet.
              • #156399
                So to get my freebie plugins onto my daw (abelton) I had to register and set up ilok, claim my plug ins, the 11 file names appeared on ilok, drag to my Mac (to authorise Mac) then had to log on to eventide support download the relevant plug in installer down load the plug ins and configure my abelton daw to see the files.
                Thanks all, it just wasn’t laid out in dummy fashion for me in the instructions. We are not all computer science grads but I got there in the end. Now to figure out how to get the best out of the plug ins…
              • #156606
                A_Eventide
                  Just be clear…even if i Max out my H9 Core with this Max Out Upgrade, I’m still not eligible for the free H9 plug in series bundle promotion? I was gonna Max it out this week just for that bundle! If that’s the case, i’d rather wait a few more weeks after the DEC 31st to not suffocate myself and Wallet for that plug in bundle. Can someone help with this question?
                • #156609
                  A_Eventide
                    That was a fast response! Thank you Eventide!
                  • #156825
                    Hi – I’ve got an H9 Max… did I miss the window for the free plugin bundles?
                  • #156827
                    joecozzi
                      Yes. That promo ended December 31st.
                    • #156834
                      jdls
                        Hi, I maxed out my H9 before 31 Dec, how can I get the plugins ?
                        Thanks
                      • #156835
                        joecozzi
                          Unfortunately, the ability to claim the H9 Bundle as a Max owner expired on December 31st.
                        • #156346
                          joeydego
                            tlongabaugh wrote:
                            Hi-
                            -Tom
                            Thanks for the reply. I opened a ticket. Definitely no claim my license tab available.
                          • #156348
                            joecozzi
                              Hi Fender17, at the moment only Blackhole is NKS compatible.
                            • #156349
                              mackie
                                hello joecozzi, do you plan to include NKS support for other plugins from the bundle? that we be so great to have them integrated into Maschine workflow 🙂
                              • #156350
                                joecozzi
                                  I agree, full NKS would rock, but at the moment, we are working on other exciting things. No current plans for further NKS support.
                                • #156362
                                  Fender17
                                    That’s a pity. It would boost workflow to agreat deal. But as I received the Bundle for free, I cannot complain at the least.
                                    What is the problém with NKS integration? It should not také much human resurces. Day per plugin at most, I guess. Is the main problem, that NI charges for using it? Or is it that when NI moves to VST3 NKS will not be needed anymore? So, you wait/do not wan’t to use resources on almost obsolete technology? Which would be understandable.
                                    I ask so much, because I miss NKS in Eventide’s plugins. And if VST3 is not solution I would make plugins “homemade” NKS, at least. Or I would ask somone to do it. So, I do no want waste my resources or other’s ones, if VST3 is the solution….
                                    I do love Eventide plugins, I have them all, or almost all. But missing NKS support breaks my workflow to a great extent. I understand that I probably belong to niche Eventide users, but I seek solution for my situaton anyway. 🙂
                                  • #156364
                                    joecozzi
                                      Inside of your iLok account, have you dragged your licenses from the iLok list into your computer or iLok dongle? That should be all it takes to authorize properly on your computer, assuming you’ve installed the plug-ins on your computer already. Once you open up your DAW, it automatically detects the licenses.
                                    • #156378
                                      tlongabaugh
                                        Fender17 wrote:
                                        That's a pity. It would boost workflow to agreat deal. But as I received the Bundle for free, I cannot complain at the least.
                                        What is the problém with NKS integration? It should not také much human resurces. Day per plugin at most, I guess. Is the main problem, that NI charges for using it? Or is it that when NI moves to VST3 NKS will not be needed anymore? So, you wait/do not wan't to use resources on almost obsolete technology? Which would be understandable.
                                        I ask so much, because I miss NKS in Eventide's plugins. And if VST3 is not solution I would make plugins "homemade" NKS, at least. Or I would ask somone to do it. So, I do no want waste my resources or other's ones, if VST3 is the solution….
                                        Hi-
                                        I'm 100% with you, NKS support for all of our H9 Plug-ins would be fantastic. I'm not a Maschine user myself, but when we added NKS support for Blackhole I found the workflow to be fantastic. It's a really slick system for the end user.
                                        The main problem is, in fact, human resources, and not NI charging or VST3 making the technology obsolete – no worries there. The reality is that the plugins dev team is quite small (as in "you-can-count-us-on-one-hand" small), and unfortunately, NKS is on the backburner right now. It takes a while to prep all of the resources and get everything packaged up nicely, and we have some really exciting new things that we are deciding to prioritize over NKS support. That doesn't mean it won't ever happen (though of course I can't promise anything…), but it won't in the short term.
                                        All that said, you could certainly add "homemade" NKS support if you wanted. I think I've actually seen this on a few forums for a few existing H9 Plug-ins.
                                        Best,
                                        Tom
                                      • #156406
                                        joeydego
                                          Send2george2 wrote:
                                          So to get my freebie plugins onto my daw (abelton) I had to register and set up ilok, claim my plug ins, the 11 file names appeared on ilok, drag to my Mac (to authorise Mac) then had to log on to eventide support download the relevant plug in installer down load the plug ins and configure my abelton daw to see the files. Thanks all, it just wasn’t laid out in dummy fashion for me in the instructions. We are not all computer science grads but I got there in the end. Now to figure out how to get the best out of the plug ins…
                                          ilok has been around quite a while now and has been a blessing and a curse. Companies have to protect their IP and its a fine balance of doing that and making the end users not jump thru rings of fire. ilok has actually gotten better over the years if you can believe it. At least now you know for next time, it’ll be easier.
                                        • #156407
                                          joeydego
                                            FWIW, you can also invest in an ilok USB key and keep all (or some) of your licenses on there so they’re portable. I have a mix of keys and computer authorizations. I don’t need the portability but I have 3 ilok keys that date back before computer authorizations were allowed.
                                          • #156607
                                            joecozzi
                                              If you max out your Core before December 31st, congratulations…you may download the H9 Series plug-in bundle for free.
