Home › Forums › Products › Stompboxes › H9 question for Eventide folks
October 6, 2015 at 8:11 pm #112916air621Participant
Is it possible to add that one feature that everyone who owns a H9 would like? Will it ever be possible to be able to create presets with more than one algorhythm?
October 6, 2015 at 8:17 pm #140884
This has been covered in the past, but …
The H9 was designed to run a single algorithm, each one of which uses most of its resources. Presumably we could make it run two weedy algorithms, but what would be the point ?
Also, you would not have enough controls to support them. For example, how would you bypass one algorithm and not the other?
October 6, 2015 at 8:46 pm #140888air621Participant
Thanks. I thought there may be some kind of processing limitation. I was thinking that it would be more for creating presets. And then I thought that you could set the expression pedal to mix the blend of say two different algos
October 6, 2015 at 8:51 pm #140889
You are right in that processing power is a factor (no pun).
Our algorithm designers have a tendency to use all the power they are given, and there is rarely much left over.
They would probably quit en masse if they were told they could only use half the power. And those who were left would produce the weedy algorithms I mentioned earlier.
October 6, 2015 at 8:59 pm #140891air621Participant
And if you’re gonna do that, may as well use cheaper materials, then raise the prices by 150%
October 7, 2015 at 2:30 am #140898
I'll pass your suggestion on to Management – they may well appreciate it…
