H9 question regarding bypass and harmonizing.
Home Forums Products Stompboxes H9 question regarding bypass and harmonizing.
    • #113610
      StSpider
      Hi, I’m considering buying an H9. However, I have two questions that I need clarified.
      1) The H9 offers multiple bypass options, including true bypass as far as I’ve read. However, I’ve also read that it is NOT possible to have the pedal in TBP mode AND use the pre/post routing option at the same time. Is this correct? It would be a major problem for me because I run a fairly dry rig and I don’t want my signal to go through an A/D/A conversion every time.
      2) H9 would be replacing my Digitech Whammy 5. I currently only use the Whammy for a specific sound: I activate the harmonizer part in the “octave” function, adding a low octave OR a high octave when the foot controller is down or up, and I “move” through the two octaves during the solo. Is it possible to replicate this with an H9 and a foot controller?
      Thank you very much.
    • #143999
      You are right about TBP. Since this is a hardware feature, and Pre/Post is a software feature, the two are incompatible. On the bright side, the H9 A/D and D/A are pretty good, so don't give up before you've tried it.
      • #144000
        StSpider
        nickrose wrote:
        You are right about TBP. Since this is a hardware feature, and Pre/Post is a software feature, the two are incompatible. On the bright side, the H9 A/D and D/A are pretty good, so don’t give up before you’ve tried it.
        But wouldn’t the signal be converted two times? I mean, I don’t want to sound like a snob “tone purist” but that can’t be good…
      • #144010
        spaceJam
        Let your ears decide.
