H9 [RCV.MAP] and program change 124-tuner
Home › Forums › Products › Stompboxes › H9 [RCV.MAP] and program change 124-tuner
Viewing 4 reply threads
    • #112708
      JES
        Hi Folks,
        I notice when switching presets with a Tech21 MIDI mouse (which just sends program change messages 1-128), program 124 puts the H9 in tuner mode.  This is cool, but would it be possible to put it in another slot?  There’s no “tuner” option in the RCV.MAP and this seems to be an undocumented feature, at least according to page 39 of the manual.
        Thanks.
      • #139880
          This is something that people asked for. It will be documented in the next revision of the User Manual. The slot is unlikely to change.
        • #139881
          JES
            Thanks for clarifying. In the meantime, can we get a list of other things lurking in program changes?
          • #139885
              Whilst there are always many scary things lurking around, this is the only secret. That I know. Oh no – maybe there are some that they haven't told me about….
            • #139929
                A further bit of information – the 124 is a default entry in the MIDImap – you can always change it to something else if you need to use this specific PC number.
                • #139942
                  JES
                    Thanks for this info! This will be invaluable for me. I know this will be documented in a future manual update, but where does one find this default entry/change it to a different PC number? Many thanks!
