H9 Registration
Home Forums Products Stompboxes H9 Registration
Viewing 5 reply threads
    • #112202
      jm197
      I am having trouble registering my H9 Max. On the registration page I have to select a product and the only options are to choose from the menu of products and the H9 isn't in the menu. It wont let me register with just the serial number. Can anyone help?
    • #127252
      gkellum
      You register an H9 using H9 Control which you can download from here:
      http://www.eventide.com/AudioDivision/Support/Stompboxes/H9.aspx
    • #127253
      jm197
      Ok Let me try that.  I have control downloaded but was trying to register with my PC
    • #127254
      jm197
      Tried it through the control app and it was very easy.  All done thanks
    • #127257
      pressure
      I finally connected the H9 thru Bluetooth on my Mac but I don't see a way to register the H9. How will I know when it is registered?
    • #127258
      gkellum
      pressure:
      When you connect your H9 to the Mac the first time, it should ask you for your Eventide username and password which will register the device to your account.  You can double check that this happened by clicking on Settings in the bottom right hand corner of H9 Control and go to Eventide Account. You should see your Eventide account information including your registered devices (H9s and any Factor pedals).
