Home › Forums › Products › Stompboxes › H9 – restoring factory program?
- This topic has 4 replies, 2 voices, and was last updated 1 year, 10 months ago by eclecticsynergy.
April 9, 2023 at 4:06 pm #170325eclecticsynergyParticipant
I accidentally overwrote the Clockworks patch in my H9 Max when I was rearranging programs.
All I could find on restoring programs in the user manual involved dumping or uploading programs via USB.
There must be a way to restore a single program without using external equipment, right?
The unit is on a pedalboard and it’d be pretty inconvenient to remove it.
Thanks in advance for any advice.
April 9, 2023 at 6:31 pm #170327brockParticipant
Can you use Bluetooth?
What algorithm was the Clockworks preset? I already guessed wrong with H910 / H949, Phaser, and Flanger.
I’ve overwritten most every Factory preset in my H9s, but it may be stashed somewhere. I may be wrong, but I think for a single preset restoration, you’re down to H9 Control and USB MIDI, or Bluetooth.
If someone here has a screenshot, it’d be easy enough to rebuild manually.
April 9, 2023 at 7:35 pm #170329eclecticsynergyParticipant
Thanks for the reply. I was afraid H9 Control would be the only answer. Don’t know how to use that, but I suppose I could learn.
Have downloaded to my laptop.
Not so sure about Bluetooth; the user guide says it works with iOS devices and my cell is Android, not an iPhone.
I found a program list that says the algorithm is Ultratap.
If somebody has the parameter values I wouldn’t mind entering them manually.
Not sure how to assign an initial algorithm when creating a program from scratch but I could find another Ultratap program and alter it.
April 9, 2023 at 8:12 pm #170330brockParticipant
Found it. A few ways to go:
- I use H9 Control on Android, so that does work.
- You can go to More … Import Preset in H9 Control under the Presets tab …
- … or you can drag ‘n’ drop it to the same spot.
https://www.dropbox.com/s/2nh5v87ke0bf4q4/CLOCKWORKS%20H9.tide?dl=0
If you rather rebuild it, just pick any UltraTap preset you don’t want, and save the changes when you’re done. It looks like the only expression pedal / ribbon mapping concerned is Length, from Whole Note to 2.5 Bar.
April 9, 2023 at 8:38 pm #170331eclecticsynergyParticipant
Awesome! I sure appreciate the help and info.
Very good to know I can use Bluetooth and my phone to program the thing,
Would’ve been harder to remove it and bring it home.
Thanks man.
And happy Easter.
