Home › Forums › Products › Stompboxes › H9 rotary FAST/SLOW help!!
- This topic has 6 replies, 4 voices, and was last updated 3 months, 1 week ago by
tonysamperi.
October 22, 2021 at 4:04 pm #159704
How do i set the Rotary Fast and Slow rates ?
The hz display over the rotor/ horn speed don’t change when i activate the Fast/Slow button . ( It just displayes SLOW before the same rate)
And it sounds like the rotors stop/brake when SLOW is activated ????
January 6, 2025 at 2:33 pm #187527
Same here. But I just had an epiphany. Are you connected via Bluetooth? On Windows maybe? I’m going to try via phone and post an update here
January 6, 2025 at 2:55 pm #187529
I confirm it’s the same…I don’t understand…
The manual is not helpful on the topic.
January 7, 2025 at 11:37 am #187556
Pressing and holding the footswitch will engage the Brake control, which will eventually stop the LFO.
A short press of the footswitch will toggle between Fast/Slow. The LFO for Fast mode is the value determined by the Rotor/Horn speed parameters. When Slow mode is engaged the LFOs will slow down by a predetermined factor, simulating a physical Leslie cabinet slowing down.
The Hz display will not change when you toggle between Fast/Slow.
Let me know if you have any other questions.
January 8, 2025 at 3:44 am #187584
I confirm it’s the same…I don’t understand… The manual is not helpful on the topic.
Thanks. I knew holding would break.
Why nowhere is what you wrote in the manual? Also, we should know what the factor is. For example I set 6Hz, so the slow will be? 1.5Hz (as per Brock’s statement)?
I also figured the slow/fast issue when you use H9 control. Basically the interface doesn’t sync well with the unit, especially if you toggle multiple times in a short span of time.
At some point the unit is maybe on slow, while the interface is on fast…reloading the preset syncs again, but of course it doesn’t stay that way.
So the best option is having an expression pedal (Luckily I have a DVP4) and use that instead. That way you choose the range and control the ramp speed with your foot.
Otherwise the second best option is having an external switch (I think I’ll get a Boss FS-7, which is the most versatile for my needs).
Other thoughts on the H9 unit
In 2025 we can’t seriously have a mini usb port. It’s time to upgrade.
The tap tempo switch should be assignable to functions like hotswitch and slow/fast where tap tempo is not needed.
In this time of digital, there should be a full routing with N effects usable at the same time (but not the mess that came out with the H90). It should be plain and simple, like Axe FX.
The unit should have a stereo fx loop (usable as dual mono even) to basically be able to place the unit in your fx chain (especially since you intend the user to use all the algorithms, like distortion, bit crusher, compressor that should be before modulations). That in 2025 would unleash the full power of such a (potentially) good multi fx pedal.
Other thoughts on the H9 effects
Flanger => Missing feedback parameter + I would let the user choose between slow/fast or hotswitch, because for most scenarios I think hotswitch would be more useful
Phaser => Missing feedback parameter
Rotary => Missing ramp time and slow time (This is a very nice rotary BTW, one of the best tried so far)
Chorus => Missing an “ensemble mode” (adding basically a second differently phased modulation on top – I know you can maybe achieve the same with the trichorus, but probably not the same)
Delay => Missing a clear interface to decide the delays routing (parallel, panned, series). I honestly didn’t get what goes on when you set A/B at 50 (might it be that the repeats are counter-phased so they “cancel” each other?).
Vintage delay => Interface not very clear, I would have preferred something like an Echorech basically (switches for the N heads) and I would add a couple of heads + swell mode
Space reverb / Trichorus / Pitchfactor => These are probably the best effects in the unit
Bitcrusher / Comp / Others => Not a fan of this kind of effects (I like comps, but not digital ones).
H9 Control
- Should allow multiple selection of presets to copy-paste (or delete) them more easily across lists and devices
- The drag&drop is too slow, you have to click and then move and you have to center precisely when you want to just move, instead of overwriting (basically overwriting is too easy, and would be pointless if you had multiple selection)
- Overall slow load/save experience
January 7, 2025 at 12:32 pm #187567
To add: (I believe I first tested this using Phaser alongside Phaser. It may apply across all of the modulation effects (?).
Fast is 4X faster than Slow, with Slow being 1/4 of the Speed set in Fast. That is, Slow 4.00 Hz. settles down to a 1.00 Hz. cycle, effectively.
January 7, 2025 at 12:45 pm #187571
… It may apply across all of the modulation effects (?) …
I should say all of the original ModFactor modulation algorithms.
My proof-of-concept Program:
