H9 Rotary Preset (Default To Other Speed When Loading Preset)
Home Forums Products Stompboxes H9 Rotary Preset (Default To Other Speed When Loading Preset)
Viewing 4 reply threads
    • #115817
      realdealblues
        Hello all,
        This seems like it should be simple but I can’t figure out how to do this (seems like it easily should be).
        I modified a factory Rotary preset and saved it as a User preset on my iPad and then loaded it to the H9.
        When I pull up the patch it always is on the “fast” speed mode and I want it to start with the “slow” speed by default.
        I thought simply opening the patch on the iPad and having it dialed in slow and clicking save would default it to the slow speed but it doesn’t.  As soon as I pull up the patch it’s always the fast spinning sound.
        Is there any way to easily change this?
        Thanks for any help.
      • #154268
        bohan
          realdealblues wrote:
          Hello all,
          This seems like it should be simple but I can't figure out how to do this (seems like it easily should be).
          When I pull up the patch it always is on the "fast" speed mode and I want it to start with the "slow" speed by default.
          I thought simply opening the patch on the iPad and having it dialed in slow and clicking save would default it to the slow speed but it doesn't.  As soon as I pull up the patch it's always the fast spinning sound.
          I just saved a user preset with SLOW on. Then I clicked this preset it's loaded with SLOW mode (the middle footswitch in the UI is engaged)
        • #154273
          camn
            there was a bug a while back with saving small changes on H9 control… maybe try saving it ON THE PEDAL by holding down some butttons ( o forget which rn).
            If the change stays persistent that way, bingo.
          • #154284
            realdealblues
              I finally got it.  I had to open the App in Demo mode and make the change.  Then pair with the H9 and “save to pedal” for it too work.
            • #154289
              camn
                yeah I never really drilled down on the inconsistency…..but it was annoying.
                I got into the habit of ALWAYS saving my minor changes using the on-pedal buttons.
