h9 Set hotknob starting position via midi
Home › Forums › Products › Stompboxes › h9 Set hotknob starting position via midi
Viewing 3 reply threads
    • #113967
      alihai
        Hi! first of all let me express how much I love this pedal and I really look forward to try the new algorithm 🙂
        So here is my problem. I created a preset on the Synthonizer that I need to be able to modify live with the hotknob (I’m not using an expression pedal)
        Is there a way to let the hotknob start on a fixed position when I engage the effect via MIDI?
        Basically I’d like to have it start all the way to the left, but instead it always loads in the last position that I used previously.
        I use a boss es8 to send MIDI to it.
        Leo
      • #145520
          Maybe you should use an expression pedal – this will always start at the value saved in the preset (to the annoyance of some).
        • #145524
          alihai
            yeah, but atm I don’t own one nor I would have space on my pedalboard… isn’t there any other solution at all?
          • #145526
              Sorry – this is the way it works, but I'll put in a request to consider a change in a future release.
              • #145527
                alihai
                  nickrose wrote:
                  Sorry – this is the way it works, but I’ll put in a request to consider a change in a future release.
                  Well thanks anyway 🙂
                  this thing is amazing, I hope you’ll be able to add this extra small feature in future!
