H9 settings / source instrument
Home Forums Products Stompboxes H9 settings / source instrument
    • #113833
      openmusic
        Dear users, I have been using two H9 since the pedal became available. I am using instruments that have no line connectivity. i.e. use a mic to capture the signal.
        In general settings the options for Instrument source are: guitar, bass, lead and bass synth. I am a bit lost and would like to know if any of these presets are optimized for a mic signal. Otherwise I would be very grateful if some other user could share useful info.
        Thanks in advance
      • #144924
        Given To Fly
          At one time, I could have sworn the options were guitar, bass, and keyboard. I am sure Eventide will explain. The simple version is if the source instrument is a bass, the PitchFactor algorithms are optimized to handle the tracking of the lower frequencies. If your source instrument is not a bass, then it is a “guitar.” So, if you are using a microphone to capture the signal of a low-frequency instrument, use “bass,” otherwise use “guitar.” If I am wrong, I am sure Eventide will explain.
