H9 Sync with Logic X Midi clock
Home Forums Products Stompboxes H9 Sync with Logic X Midi clock
Viewing 3 reply threads
    • #112437
      soleux
        Hello, Im trying to get my H9 sync via Midi with logic X, i just want to record some guitars and get some delays and  pitchshifter effects to sync with the song's tempo , Im using a Motu Microlite
        I have been able to sync the H9 with strymon pedals and other eventide pedals but no with my Daw
        Thanks for the help!
      • #127649
          Sorry – you are giving us no information. Please help us to help you and tell us:
          (1) What did you do ?
          (2) What happened ?
          (3) What did you expect to happen ?
        • #138585
          soleux
            Thanks Nick for answering so quick,
            1. i connected the midi out of the microlite to the midi in of the h9, I set the pedal to be the slave, but i cant figure out how to send the info from logic to the pedal so they sync
            2. the pedal dont follow the song tempo
            3.I wanted the delay sounds sync with the beats i created in logic(ultrabeat)
            sorry Im new with Midi  maybe this is extremely easy but im lost
            thanks again
          • #138586
              soleux:
              By this I assume you mean set [CLK IN] (MIDI Input Clock) to ON. Does the display flash when you do this ? If so, it is not seeing the MIDI clock.
              soleux:
              In what way ? Does it show BPM values if you change the master tempo ?
              If it does not show the BPM values, the problem is with your DAW.
