H9 Tap Temp Issue
Home › Forums › Products › Stompboxes › H9 Tap Temp Issue
    • #111699
      jcalama
        So I'm having a problem Tapping Tempo in when the unit is set to "Tempo On" and displays BPM. Stepping on the Tap switch displays the current tempo, but multiple taps fail to change it. When I set it to "Tempo Off" and display reads in ms, the tap switch functions as expected, changing the ms according to how fast or slow I tap.
        What am I missing here…I'm quite confused as it is clearly not a faulty switch.
        Thanks,
        Juan
      • #126115
          Make sure that MIDIclock in is OFF.
