H9 – Tap tempo when tempo is on not possible?
Home › Forums › Products › Stompboxes › H9 – Tap tempo when tempo is on not possible?
    • #112120
      cbellanga
        Guys, maybe it's a stupid question but haven't been able yet to sort this.
        I understand that you can tap tempo using the right footswitch when tempo is off. So when I'm tapping I can see the pedal updating the time in ms.
        But I can't do the same when tempo is on.. Is that right?
        For example, I want to have a twin delay set to 1/4 and 5/16 respectively and be able to tap with the right footswitch to change the relative speed but nothing happens. I only see the original saved bpm while tapping.
        I can actually use the knob for changing the speed but that's not really helpful when playing live.
        Is that a limitation or I'm missing something? Thanks!
      • #127078
        wedelich
          This would occur if MIDICLK IN is set to ON.  Make sure it's set to OFF in the system mode if you don't want to use MIDICLK.
        • #127120
          cbellanga
            great, it works now, many thanks 😉
