H9 to Micropitch Midi Cable
Home Forums Products Stompboxes H9 to Micropitch Midi Cable
Viewing 3 reply threads
    • #162368
      danman200
      Connecting a H9 to Micropitch Midi Cable. Is it Midi out of H9 to a 1/4″ TRS plug into the Exp input? That is how I read it in the manual. TIA.
    • #162369
      joecozzi
      That is correct. Just in case, here’s how the cable should be wired.F3E6003D-AADE-4F7C-83B7-F094B3F61850
    • #162379
      danman200
      Thank you so much, I appreciate the diagram.
    • #162438
      If you have an early H9 (before serial 16329) you will need to make a simple soldering mod to it. See https://www.eventideaudio.com/forums/topic/h9-modification-for-midi-power/
