Home › Forums › Products › Stompboxes › h9 usb vs h90 usb
will I be able to use the same cable on the h9 usb as I have on the h90?
have a h90 and have just bought a h9, only just realised that the rear connectors might be different and only have one cable!
No you cannot use the same cable since the H90 uses a USB-C type cable. The H90 ships with the appropriate USB cable, did you not receive this?
found it now 🙂
Is it possible to order a replacement cable? If not, what specs to I need to shop for?
Thank you!
We don’t currently offer replacement cables in our store. Any USB cable that is for data transfer (not charging) should work fine. Do not use a cable that is longer than 3 meters.
