H9 – Using KB parameter controls: How to?
Home › Forums › Products › Stompboxes › H9 – Using KB parameter controls: How to?
Viewing 3 reply threads
    • #114041
      How are you using KB – knob parameter controls – in your midi environment? I am trying to grasp more sense on what can be midi controlled on H9 and how can be useful for me in my setup. Are you using these KB0~KB9 with more expression pedals over midi?
    • #145857
      mwe
        One thing I’ve done is set up a template on a Novation MIDI keyboard to control each knob. I don’t envision ever using it during a show but it’s very handy when I’m tweaking presets. I guess it’s the tactile thing of actually turning a knob. I’ve also played around a little with a plugin I’ve written for Reaper. It let’s you control the H9 from within the DAW. You certainly could use an expression pedal to control a specific knob CC but I think it might get a bit tedious. Of course, one man’s tedium is another man’s amusement.
      • #145861
          You can map the KB0-KB9 knobs [AKA Parameter 1-10] to discrete MIN and MAX values.  If you have MIDI switches that can send one or more CC values, you can configure quite a few unique tricks.  Switching between pitch intervals, filter positions, modulation rate changes, single note delays & reverbs, etc.
        • #145862
          Thank you for your thoughts. I was wondering about how to best use it in a guitar rig…
