Easy: insert a split before your H9 and send the dry signal directly to your Friedman, while the other of the two signals is send to your H9. Ideally, the splitter will include a phase reversal and ground lift circuit so you can eliminate any unwanted hum or phase cancelations. The Lehle P-split is a good passive solution. Not cheap, but excellent quality.
