Home › Forums › Products › Stompboxes › H9 Wish: level control knob on the hardware
June 14, 2016 at 11:31 am #113507
Bodde
ParticipantI wish there was a seperate control/knob on the hardware for the total patch output level.
In live situations you sometimes have to adjust the volume level of the patch (I don’t mean the mix but the overal level of the patch). Now this can only be accessed throught the software if I am correct? This is not very practical live when you want to adjust the level on the fly and are not hooked up to the sofware.
Or is there another way to do this (without expression pedal)? and can the level be assigned to one of the little XYZ knobs? or maybe the hotswitch? How do you guys deal with this?
June 14, 2016 at 11:34 am #143575
gkellum
Participantbodde wrote:I wish there was a seperate control/knob on the hardware for the total patch output level.
You should be able to do this by pressing long pressing the left footswitch and going to preset output gain; that brings up a set of special preset specific system parameters like preset output gain, routing modes, etc. While holding the left footswitch, pressing the big black wheel cycles you through these parameters. Turning the big, black wheel changes the parameter value.
June 14, 2016 at 7:03 pm #143581
Bodde
Participantgkellum wrote:bodde wrote:I wish there was a seperate control/knob on the hardware for the total patch output level.
ok thanks! Didn’t know that. It seems a bit impractical though if you have to scroll through parameters when you want to adjust the level quickly on the fly. Would be better (for me) if there was a seperate level knob or if it could be assigned to an XYZ knob. But I have to try it.
June 14, 2016 at 8:05 pm #143586
gkellum
Participantbodde wrote:ok thanks! Didn't know that. It seems a bit impractical though if you have to scroll through parameters when you want to adjust the level quickly on the fly. Would be better (for me) if there was a seperate level knob or if it could be assigned to an XYZ knob. But I have to try it.
I agree. It would be better if Preset Output Gain were available along with the other paramters as well under the XYZ buttons.
June 15, 2016 at 7:31 am #143588
Bodde
Participantgkellum wrote:I agree. It would be better if Preset Output Gain were available along with the other paramters as well under the XYZ buttons.
Do you think that is possible for future updates? I am not sure if I really need the other parameters but output gain under the XYZ buttons would be very handy. That’s something I really miss in a live situation.
June 14, 2016 at 8:53 pm #143587
dagjonas
MemberOr maybe one could assign any parameter wanted from the H9 Control to f.ex. the Hotknob? A button I don’t use.
June 25, 2016 at 12:01 am #143649
h9-nz
ParticipantAlternatively or additionally, I would like the output level in H9 Control to be assignable to expression pedal.
June 25, 2016 at 12:46 am #143650
gkellum
Participanth9-nz wrote:Alternatively or additionally, I would like the output level in H9 Control to be assignable to expression pedal.This is already supported. In H9 Control in the presets screen, if you look under the More menu, there is an option to assign the output level to the expression pedal. You can also globally assign the expression level to the output level for all presets under Pedal / General Settings. You can do this on the H9 as well. Instructions for doing that are in the latest version of the H9 manual.
June 25, 2016 at 3:18 am #143651
h9-nz
Participantgkellum wrote:h9-nz wrote:Alternatively or additionally, I would like the output level in H9 Control to be assignable to expression pedal.This is already supported. In H9 Control in the presets screen, if you look under the More menu, there is an option to assign the output level to the expression pedal. You can also globally assign the expression level to the output level for all presets under Pedal / General Settings. You can do this on the H9 as well. Instructions for doing that are in the latest version of the H9 manual.
Does that override existing expression pedal assignments though? I would like to add output level changes to other parameter changes, for example: in Crushstation have the expression pedal control gain from 15-30 and output volume from 0dB to +6dB at the same time.
June 25, 2016 at 1:06 pm #143655
gkellum
Participanth9-nz wrote:Does that override existing expression pedal assignments though?
No. If used on a per preset basis, you can also use other expression pedal assignments.
h9-nz wrote:I would like to add output level changes to other parameter changes, for example: in Crushstation have the expression pedal control gain from 15-30 and output volume from 0dB to +6dB at the same time.
Oh, well that it doesn't do. It doesn't give you an assignable range of output volume. It goes from silence to full output volume over the range of the expression pedal.
June 25, 2016 at 10:40 pm #143659
h9-nz
Participanth9-nz wrote:I would like to add output level changes to other parameter changes, for example: in Crushstation have the expression pedal control gain from 15-30 and output volume from 0dB to +6dB at the same time.
[/quote]
This would be very useful, for me anyway. In H9 Control it would be great to have the output volume slider able to be set min and max expression pedal values like all the other knobs. -
July 11, 2017 at 1:26 am #146766
snakle
Memberh9-nz wrote:gkellum wrote:h9-nz wrote:Alternatively or additionally, I would like the output level in H9 Control to be assignable to expression pedal.This is already supported. In H9 Control in the presets screen, if you look under the More menu, there is an option to assign the output level to the expression pedal. You can also globally assign the expression level to the output level for all presets under Pedal / General Settings. You can do this on the H9 as well. Instructions for doing that are in the latest version of the H9 manual.
This is exactly what I’m trying to do but I can’t figure it out. Has this feature been added yet? The new Fuzz effects can get extremely loud very quickly so I’d like to be able to do this with my expression peda as I go from 0 to 100:
- Go from 0 to 3 AMT
- Increase delay level slightly
- Reduce Output volume
Otherwise I have no practical use for an expression pedal on this preset… everything just becomes tooooo loud.
June 25, 2016 at 10:43 pm #143660
h9-nz
ParticipantAlso, apologies to the OP for diverting his topic. However, if he has no expression pedal, the hotswitch performs the same function. Cheers.
