H9 with 5 footswitches
Home › Forums › Products › Stompboxes › H9 with 5 footswitches
Viewing 3 reply threads
    • #116032
      flat5
        Can an H9 using a Barn3 (giving 4 pushbuttons plus a momentary pushbutton connected to the right jack on the Barn3) be configured to yield:
        H9 Hot Switch: disabled
        H9 left: Engage/Bypass
        H9 right: Tempo
        Barn3 left: Patch down
        Barn3 right: Patch up
        Barn3 momentary sw in jack: Hot Switch
      • #155507
        bohan
          flat5 wrote:
          Can an H9 using a Barn3 (giving 4 pushbuttons plus a momentary pushbutton connected to the right jack on the Barn3) be configured to yield: H9 Hot Switch: disabled H9 left: Engage/Bypass H9 right: Tempo Barn3 left: Patch down Barn3 right: Patch up Barn3 momentary sw in jack: Hot Switch ???
          Yes, that's doable. All 3 aux switches' functions are assignable.
        • #155508
          flat5
            Thanks! Five assignable switches is great. What position for the Barn3 switch?
          • #155513
            camn
              A MIDI controller with 5 assignable switches would cost, like, $35 to make.
            • #155510
              bohan
                The 2 switches on the pedal are not assignable. The left one can only bypass/active, the right one can either increment/decrement presets or tap tempo.
                3 aux switches are assignable, you can set the function mappings for Tip, Ring, Ring/Tip easily in H9 Control. See OX9's manual for more details of which switch is which:
                https://static1.squarespace.com/static/539f0880e4b0e0318ea3192f/t/5940029fb8a79bde2d979ab5/1497367242457/OX9-Manual-2017.pdf
