H90 1.7.1 not syncing to MIDI Clock
Home Forums Products Stompboxes H90 1.7.1 not syncing to MIDI Clock
Viewing 3 reply threads
    • #176924
      ed536m
      I updated my H90 to 1.7.1 and the tempo is not syncing to MIDI Clock. I have a Morningstar MC6 pro and prior to the H90 firmware update it worked flawlessly. After it does not sync to midi clock tempo. All the other midi pedals in my chain sync to tempo. But not the H90
    • #176925
      fiddlercrabseason
      1) If running Morningstar 3.11 firmware (maybe earlier too?), try sending a clock ‘start’ message from the MC6.
      2) If running the new Morningstar 3.12 firmware, try:
      a) de-selecting any one of the MIDI clock port settings (new feature in General Config),
      b) save & restart MC6,
      c) change that setting back again (if you don’t want/need to change it back, see step ‘e’),
      d) save & re-start MC6,
      e) try sending the clock ‘start’ message again.  If still no go, reboot H90, then send the clock ‘start’ message again.
    • #176985
      buschi
      I can confirm, no MIDI-Clock at all !!
      Not over DIN or over USB.
      I’ve tried to send the clock from cubase etc…
    • #177015
      Sorry to hear you are having issues with MIDI clock, but I cannot reproduce this. MIDI clock is working correctly via DIN or USB on my H90 running 1.7.1.
      Please note that you must set the clock source to MIDI Clock in the Tempo Menu and also set the MIDI Clock Source to either DIN or USB depending on your configuration. https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/system-menu/midi.html
