H90 1 Button Looper
Home Forums Products Stompboxes H90 1 Button Looper
Viewing 3 reply threads
    • #172087
      cjcampbell2000
      Hi guys. so I’m trying to find the 1 button looper but can’t seem to find it anywhere. I’ve looked under the looper section and found all the others. Soooo I’m using the basic looper for now. But cant even see how it turns on. the manual doesn’t really say anything to help, press 1 button to record a loop, again to stop. 2 times to stop playing the loop. ok I got that But
      WHERE IS DA BUTTON THEN
      Gosh, I’m sooooo frustrated. Any help would be greatly appreciated thanks
    • #172088
      coirbidh_99
      The Looper controls are options for the Perform mode switches. Once you’ve assigned the Looper to a program, you can set the 1-Button Looper or other controls to that preset’s Perform switch (or to external switches or MIDI).
    • #172089
      joecozzi
      In PERFORM mode, press the LED button above the footswitch that corresponds to where the Looper algorithm is located – A or B. Find the “1-BUTTON L” option. Once that’s been assigned to the footswitch, you may control the looper according to the instructions in the manual.
    • #172095
      cjcampbell2000
      Thanks a million worked a charm.
