Home › Forums › Products › Stompboxes › H90 + Ampero Switch and Mission SP-H9
- This topic has 12 replies, 3 voices, and was last updated 1 year, 11 months ago by joecozziEventide Staff.
February 9, 2023 at 1:34 pm #168993pederberndParticipant
Hi Guys,
I’m having trouble with my Ampero Switch in combination with the H90 and a Mission SP-H9 where the H90 only recognises the left switch of the Ampero Switch. When I use the calibration it doesn’t even react when I push the right button. I already tried it on my h9 and there it works without a problem so I’m lost here. The switch itself cannot be the issue but maybe someone else has an idea. I already swapped EXP1 and 2 but the same result. I also tried with a TS cable instead of the TRS cable but also no success. Any help would be much appreciated!
Thanks a lot in advance!
February 9, 2023 at 2:25 pm #168995
Did you configure the EXP inputs to function with an aux switch instead of an expression pedal?
February 9, 2023 at 2:26 pm #168996
Also, the inputs of the H90 are either for an aux switch or an expression pedal, not both on the same input.
February 9, 2023 at 2:28 pm #168997pederberndParticipant
Yes I did. Switched them also accordingly when I changed between EXP1 and 2. It’s really weird to me.
February 9, 2023 at 2:30 pm #169000
Are you using a TRS cable with the switch?
February 9, 2023 at 2:30 pm #169002pederberndParticipant
Yes and also tried with a TS cable
February 13, 2023 at 3:30 pm #169089pederberndParticipant
Any other idea?
February 13, 2023 at 6:49 pm #169090brockParticipant
A real shot in the dark here: The SP-H9 has a toe switch, as I understand it (never used it). Is it possible that internal switch on the Mission is ‘stealing’ the right footswitch from your Ampero?
I would try this: TS cable out from the Mission expression pedal. Or better yet, unplugged from the H90 completely. Try to calibrate the Ampero dual switch on its own, using a TRS cable.
Then unplug the Ampero, use the same TRS cable to the Mission, and calibrate the SP-H9 by itself. First as an expression pedal, then re-calibrate it as an Aux Switch, while pressing down on the toe switch.
February 14, 2023 at 6:13 am #169093pederberndParticipant
That could really be it. I’ll give that a try when I’m back from work. Thanks a lot for your input!
February 15, 2023 at 1:45 am #169114pederberndParticipant
Unfortunately this also didn’t work so I started with the easiest setup and only connected the switch. But even then it’s only recognising one of the buttons. I tried with both inputs and changed to FS1-3 or FS4-6. In the appended video you can see what I’m doing. I tried with a TRS cable in the video. When I do the same with a TS cable one button works like with the TRS cable but the other one is always on. I feel like I’m missing something trivial here or is there another setting I need to make?
February 15, 2023 at 5:45 am #169115brockParticipant
Fresh out of ideas here. I can’t think of any settings you may have missed.
It seems unlikely that the TRS cable or one Ampero switch went bad, as you say they worked just fine in the H9.
You could verify by testing the TRS with an ohmmeter / multimeter for continuity. Or a known good TRS out the Ampero to meter-test it. All I got.
February 16, 2023 at 1:29 am #169156pederberndParticipant
well it turned out to be the cable 🤦🏻♂️
i think it went bad when I moved everything on the board and didn’t check again afterwards with the H9 but only the H90. Sorry for all the hassle! Got it working now! Thanks a lot guys! Have a good day 😄
February 16, 2023 at 6:48 am #169159
Thank you for reporting back. We really appreciate it.
