H90 and Fractal VP-4
Home Forums Products Stompboxes H90 and Fractal VP-4
    • #187142
      sigitar
      I want to use my H90 together with my new VP-4 from Fractal Audio.
      Can the setup be wired so that the effects from the H90 can be used in the effects chain of the VP-4? If so, what is the best way to wire it up?
      Thank you in advance!
    • #187144
      I’m not very familiar with the VP-4, but it looks like there is a dual path mode. This would allow you to put the H90 between the VP-4 Path 1-2.
      See page 19 of the manual: https://www.fractalaudio.com/downloads/manuals/VP4/VP4-Owners-Manual.pdf
      I’m sorry, but I do not have much further suggestions for how to use the VP-4.
      The above setup will be mono, so you’ll need to do something else if you’d like to use your pedals in stereo.
      • #187146
        sigitar
        Thanks for your tipp! Good idea, but I want to go stereo, so I am thinking about whether it is better to put the VP-4 into the H90 as an insert (and then position it accordingly) or in dual mode, with one side before and one side after the VP-4?
    • #187148
      The VP-4 as a stereo insert in the H90’s signal path would be more flexible, I would suggest that.
