h90 and HX stomp
Home Forums Products Stompboxes h90 and HX stomp
    • #169536
      MarMar84
      I have a routing question.
      Here’s my optimal signal chain.
      COMPRESSOR > H90 > DRIVES > HX STOMP > STOMP STEREO SEND > H90 > Source Audio COLLIDER > HX STEREO RETURN > HS STOMP MAIN OUTS
      I would like to have the option of pitch shifting before drives while still enjoying the modulation capabilities of the h90 in the loop of the HX. Can this be done? If so can you help me set this up? I having trouble understanding where to plug all the cables.
      thanks!
    • #169594
      Yes, this is possible using Dual Routing – https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/edit-modes/routing.html#dual-routing.
      Start by enabling Dual Routing in the System settings. You can connect your gear to the H90 as follows:
      • Compressor Output > H90 input 1
      • H90 output 1 > Drive Input
      • HX Stomp Stereo Send > H90 Inputs 3-4
      • H90 Outputs 3-4 > HX Stomp Stereo Return
      Path 1 will be after the compressor and before your drive pedals. Path 2 will be in the FX loop of the HX Stomp. Pressing the routing button on the H90 will allow you to choose which H90 Preset is on which Path. You can view the link to the user guide I shared above for more information.
      Let me know if you have any questions.
