H90 and HX Stomp Routing
Home Forums Products Stompboxes H90 and HX Stomp Routing
Viewing 3 reply threads
    • #182946
      toysdeguzman
        Hi!  What’s the best way to connect the H90 and HX Stomp so I can:
        1.  Play preset A before HX Stomp amp
        2.  Play preset B after HX Stomp amp
        3.  Play both H90 presets before HX Stomp amp
        4.  Play both H90 presets after HX Stomp amp
      • #182947
        Sorbz62
          Put the HX Stomp in an H90 loop, then you can move it around in the pedal order.
          Jim
        • #183549
          deepteal
            @ geometry dash
            As far as I know, the best way to connect the H90 and HX Stomp is to put the HX Stomp on the H90 ring, then you can move it in pedal order.
          • #183589
            frank_loomis
              The way I do it is to run the H90 in dual routing mode and go into the H90 input 1 > HX stomp input. Then use the HX stomp FX send > H90 input 3/4, then H90 output 3/4 > HX Stomp FX return.
              You can then use the H90 routing options to either have both effects on H90 path 1 (both effects before the HX stomp amp), 1 effect on H90 Path 1 and another on Path 2 ( 1 effect before the HX stomp Amp and after the amp using the FX Loop), or have both effects on H90 path 2 (and have both effects after the HX stomp amp in the effects loop). It’s a really flexible approach!
