Home › Forums › Products › Stompboxes › H90 and MIDI Buddy MP 128P
- This topic has 7 replies, 3 voices, and was last updated 7 months, 4 weeks ago by
Eventide Staff.
July 15, 2024 at 7:26 pm #183755
niteboater
Participantyeah my MP128P still works after all these years, built like a tank.
I want to connect it to my H90 but not sure if a 5 pin DIN to usb c cable will work…
July 15, 2024 at 7:39 pm #183757
niteboater
Participant -
July 16, 2024 at 3:46 am #183759
udi9
ParticipantWhy do you need a USB-C cable?
Can’t you just use the MIDI In port on the H90?
July 16, 2024 at 10:25 am #183776
niteboater
Participantwhy do I need a USB-C cable? Other then the fact that its the only way to get MIDI data in and out of the H90 – I dont – am I getting your question correctly?
Im hoping to connect the 5 pin DIN connector – very old school – to the H90… which does not come equipped with the old style connector, but instead uses a modern USB-C port
July 16, 2024 at 10:38 am #183780
The H90 has a 5-pin DIN MIDI input. I would suggest connecting the controller to the H90 that way.
July 16, 2024 at 10:40 am #183782
udi9
Participant🙂
July 16, 2024 at 3:41 pm #183814
niteboater
Participantmy apologies, I assumed it didnt have this having found the USB C port first… looks like its working!
July 16, 2024 at 3:45 pm #183815
No problem, glad to hear it is working!
