H90 and Mission SP-H9
Home › Forums › Products › Stompboxes › H90 and Mission SP-H9
Viewing 10 reply threads
    • #168145
      BengtN
        I’m trying to get this expression pedal to work with the Vintage Wha preset but no luck so far. I’m probably missing some setup steps, but I can’t figure it out.
        The pedal is connected to EXP/CTR 1 with a T/R/S cable and “Pedal 1” is set to Exp 1 under Input/output on the System/Settings tab in H90 control. It is not possible to map “Expression 1” to any parameter on the external control tab as the option is greyed out.
        I have calibrated the pedal successfully on the unit.
        What am I missing?
      • #168171
          From memory, so forgive any inaccuracies.  I think you are trying to map the expression pedal from the Performance Parameters?  See if you have better luck under Parameters Edit.  Press & hold the Quick Knob under Manual for a classic wah action.
        • #168176
          BengtN
            That’s it. Thanks!
          • #168178
            joecozzi
              Select the Q-Wah algorithm and go into PARAMETERS. Set Mod Source to “Manual.” Then, map Manual Mod to your expression pedal by holding down the Quick knob to enter Parameters Mapping. Under Ctl Source, map it to your expression pedal or set it to LEARN and move your expression pedal. The H90 will automatically detect the expression pedal. Adjust the Q-Wah’s Intensity, Bottom, and Depth to taste.
            • #168329
              jk68594
                Hey guys,
                this is closest subject I can find to my issue:  I’ve got a new Mission SP H9 and I can’t get it calibrated to my H90.  From heel to toe only about 40% of the expression range is accessible.  How do I get the expression pedal calibrated to my H90?  Thanks!
                • #168335
                  joecozzi
                    Before you do anything, always make sure you connect your cable to the expression pedal first and then you connect the pedal to the EXP input of the H90 last. Doing things in the wrong order won’t allow any pedal to sense the proper load. To calibrate, go in the Systems settings > I/O > third page,  you can use the third quick knob to enter the calibration sequence. Make sure as you sweep the pedal from heal to toe that it goes from zero to 100 and back.
                • #168340
                  jk68594
                    That did it, thank you!  Great products + great customer service = EVENTIDE
                  • #169559
                    AntCece
                      Hello there, someone with some info about how to activate or map Mission Sp h9 toe switch with H90?  Thanks!
                    • #169560
                      joecozzi
                        Not possible because unlike the H9, the H90 does not have a “Both” mode for an expression pedal and aux switch on the same EXP input.
                        I haven’t tried it but maybe with a TRS to dual TS cable you can connect one end to EXP 1 for expression and the other to EXP 2 for aux switch.
                        • #174483
                          breubo
                            So I’ve tried the TRS splitter from SP-H9 to each EXP input. EXP1-Pot, EXP2-Sw. I can not get the AUX switch to control the Parameter Act/Byp. Does this Function work at all?
                          • #175160
                            ejimenez76
                              As previously asked by @carouzal, is this function going to be added in an upcoming update for the H90? I also bought an SP-H9 because I thought the switch would work…
                            • #175203
                              breubo
                                This works……….need a TRS to Dual TS
                                SP-H9 – TRS to dual TS cable, connect one end to EXP 1 for expression and the other to EXP 2 for aux switch(4).
                                In H90 Control, go to Control Assignments > Performance Parameter Mapping, select P switch > Parameter: Act/Byp > Control Source: Aux Switch #4. This will make the switch act/bypass the Program. Make sure you save the Program when you are done.
                                You can also go to System > External Control and map this globally so the aux switch does act/bypass for every Program.
                              • #175204
                                carouzal
                                  I think our point was the h9 does this with one aux port.
                                  I don’t want to give up my 3 button switch for this functionality.
                                  Eventide resellers are implying that these two work together. Even including cables that will not make it function as implied.
                                  https://www.sweetwater.com/store/detail/H90ExpBun–eventide-h90-harmonizer-multi-effects-pedal-with-expression-pedal-bundle
                              • #171229
                                carouzal
                                  Will this feature be added in the future? I just purchased an sp-h9 because I thought the switch would work.
                                  • #172319
                                    breubo
                                      Same here, one of the reasons I bought both. I hope the feature is possible and it does get added.
                                      Going to try the splitter method suggested by joecozzi.
                                    • #174480
                                      breubo
                                      • #174489
                                          If you’ve assigned EXP2 to Sw,  then the SP-H9 footswitch should correspond with SW4 on the H90. Did you assign the Act/Byp parameter to SW4 in Perform mode?
                                        • #174495
                                          breubo
                                            I did. Is there a reboot process or something similar to engage the selection? Just checking, in case.
                                            I also checked cable and SP-H9 switch functionality with a multi-meter.
                                          • #174496
                                              You should not have to reboot, you just need to calibrate and map the controller.
                                              Just to confirm, you’ve calibrate the footswitch and when you depress it, Sw4 turns on and off on the H90 UI?
                                              If that works, can you try mapping a parameter, selecting “Learn” for the control source, and pressing the footswitch?
                                              https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/edit-modes/parameters.html#mapping
                                            • #174498
                                              breubo
                                                I have not calibrated, I will calibrate tonight and give it a try.
                                              • #174500
                                                breubo
                                                  I got it to work. Not sure exactly how, but it looks like to me that you can only map/assign from the pedal. The H90 control indicates that you’ve made the change but the pedal does not follow. Does that make sense?
                                                  bob
                                                • #174501
                                                    Glad to hear you got it working. I’m not quite sure what you mean, the mappings can be made using the pedal or the software. I just tested this and it is working correctly.
                                                  • #174502
                                                    breubo
                                                      I couldn’t get it to work via the H90 control, for whatever reason. It accepted the change at the pedal. Not sure why or what I did wrong. I plan on resetting at some point and attempting this process to assure I have it correct. Thanks so much for your help!!!!
                                                      Regardless, for those looking to use the Expression pedal to mimic a Wah Wah Pedal, here’s the process.
                                                  • #177048
                                                    winihh
                                                      Will the expression + toe switch on one input of the H90 will be implemented in the future?
                                                      This would be a reason for me to invest in the Mission Engineering SP-H9.
                                                      Thanks for your great support!
                                                      • #177053
                                                          Sorry, we do not plan on supporting this. It’s not necessary since the H90 has two exp/ctl inputs. You can use a TRS splitter and connect the SP-H9 to both of the H90’s exp/ctl inputs if you’d like to use both the switch and expression pedal.
                                                        • #180710
                                                          paulmarshall
                                                            I have a song where I use wah and also tap temp for echo in another part of the song. So if I use both H90 inputs for my wah using a splitter (exp1 = mod and exp2 = act/bypass) is there another way I can add in a tap tempo?
                                                          • #180711
                                                            apalazzolo
                                                              You can assign one of the H90 footswitches to be your tap tempo switch in Perform mode.  Using the Control app, select “Control Assignments” at the bottom of the Edit screen and click around there a bit.  You’ll get it.
                                                          • #194537
                                                            stma1990
                                                              Weird question and apologies if this is the wrong thread for the topic, but if I’m using a TRS Y-cable to connect an SP-H9 to EXP-1, is it possible to plug in a dual aux switch into EXP-2 to leverage as the 5th and 6th aux switches of the “Aux Switch 4-6”?
                                                              • #194538
        Can you please clarify? If you use a TRS Y-cable from the SP-H9, that would require you to use both Exp1 and Exp2 jacks on the H90.
        • #194539
        joecozzi
        Keep in mind the H90 does not have a “BOTH” mode like the H9 where you can connect both a switch and an expression pedal simultaneously into the same EXP input. You would need to connect the TIP end of the SP-H9 to EXP 1 for expression and the Ring end into EXP 2 for the switch to work simultaneously. If you just want to use the SP-H9 as an expression pedal, then yes, you can just connect the TIP side to EXP 1 leaving EXP 2 available for a dual aux switch.
