H90 Aux Switch assignment issues
Home Forums Products Stompboxes H90 Aux Switch assignment issues
    • #180019
      StrolloSound
      Currently using 2 H90s each with their own Digitech FS3X 3 way footswitches as my “Aux Switches”
      One H90 is not allowing Performance Parameter Mapping of the Aux Switch.
      I am simply trying to map the Aux Switch to Active/Bypass for the on board switches 1,2,3
      I can only get the second (A) onboard switch to map to the foot switch
      Confirmed in I/O that Pedal 1 is set to switch 1-3
      The other H90 is allowing for each switch to be mapped normally
      Both are running software version 1.7.5.29
      swapped both cables an multiple foot switches same result
      Any suggestions?
    • #180020
      All I can say initially is to try calibrating/re-calibrating the 3-Aux in the misbehaving H90.  That sounded like it might have been a TS cable issue, but you’ve already checked all of the potential combinations.
      I have a similar setup here. Let me see if I can come up with anything else that might be the cause.
    • #180021
      StrolloSound
      Re calibration did it –
      I thought it was only for expression pedals
      Thank You!
