I’m continuing to work on remotely controlling the H90 and when I powered everything on today, when I sent MIDI signals to activate or bypass a program or effects A and B, the H90 becomes unresponsive and won’t respond to anything, including onboard switches. This is also true when I connect the footswitch directly to the H90 and assign them to the bypass functions.
Is there a way to have the H90 respond to both DIN and USB MIDI? It would be nice to be able to have it connected to my computer via USB and also to the MC6 Pro via DIN so I can edit and then demo everything.
Glad to hear that the issue is not happening anymore. Please let us know if you experience any similar issues.
Yes, you can use DIN and USB MIDI simultaneously. The MIDI clock source must be either DIN or USB, but you can use the other MIDI functions simultaneously.
