H90 Bypass and Active
Home Forums Products Stompboxes H90 Bypass and Active
    • #184034
      markninel
      Hi Dear Eventide stuff
      My h90 works with a Free the tone arc-4 midi controller.
      For example, the two prestets of my controller are the same prestet of H90, and they are both in prestet A bypass status. When I switch any two prestets in the controller, preset A in my h90 will be automatically turned on. Once and then off again, I can more clearly see its activity when I connect to Bluetooth. But this problem will not occur if prestet is in the active state, and it will not be turned on and off.
      The settings in my controller are value 65on/63off, and H90 is Act/Byp(M).
      Hope you can help me, thank you!
    • #184035
      markninel
      video
    • #184059
      Sorry, it’s not clear what the issue you are describing is and it looks like your video did not get sent.
      Please email support@eventideaudio.com and you can send the video there.
