Hi everyone,
I encountered something on the classic chorus algorithm, and I’m unsure if it’s a bug or a feature on this specific effect.
Basically, when I move the filter parameter on the chorus effect (classic mode), I expected to remove higher or lower frequency depending on how much I turn the knob to either side.
But when I try it, it seems to only add a static high pass filter from -100 to -1, flat to 0 and a static low pass filter from 1 to 100.
Is it the intended way the filter should behave, or is it a bug?
Thank you!
