Home › Forums › Products › Stompboxes › H90: connecting multiple inputs (one stere plus one mono)
- This topic has 6 replies, 4 voices, and was last updated 9 months, 3 weeks ago by
Eventide Staff.
August 11, 2023 at 12:54 pm #173077
I want to connect a stereo and a mono input. Is there such possibility?
Thank you
August 11, 2023 at 1:21 pm #173078
Can you describe what you’re trying to do please? Do you want to use two instruments at the same time with the same effects or do you want each instrument to have its own effect?
August 11, 2023 at 1:55 pm #173079
I want to have a stereo input and a mono input at the beginning of the signal chain, as they were mixed before being processed.
They should share the same audio routing then. -
August 14, 2023 at 11:46 am #173126
It sounds like you want to connect two instruments and process them both with the same effects. Connect the stereo one to inputs 1&2 and connect the mono input to Input 3. Position Insert 1 before the presets and make sure the Insert Mix is set to 50%. This mixes the signal from the stereo input and the mono input and you can route it to two Presets in either serial or parallel configurations.
August 15, 2023 at 11:57 am #173168
Thank you Joe,
will test this and check if mixing the two sources at 50% is manageable in terms of input volume.
November 19, 2025 at 11:54 am #193371
Hi there, reviving this question I guess 😉
So, I tried this. I have 2 synths: 1 stereo, 1 mono out. Even thinking of connecting a 3rd mono synth to input 4…
Want them all to be processed through the H90, like a mixer would: so whether or not any program is active, all inputs are ‘processed’ with the 50% mix level.
Also watched the ROUTING video…Is it correct that the above solution seems to only work when the Program is ENGAGED and that stereo1/2 is the only signal coming through when NOT engaged?
Is there a way to process the signals of ALL synths, even when the program is not active?
Or should I use some trick like create a new program with 2 presets @0%wet…?
Not very elegant, maybe you can help me with another solution without me having to spend some more cash on an additional mixer like the Radial Key Largo?Maybe I am just missing something otherwise I’llm put a feature request for this I guess 😉
Kind regards… RB
November 20, 2025 at 8:26 am #193382
This will work when the Program is bypassed. You need to set Program bypass mode to “AB Only” https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/system-menu/global.html
Give it a shot and let me know if you run into issue.
