H90 Control 1.4.1 – problem typing in HotSwitches values
Home Forums Products Stompboxes H90 Control 1.4.1 – problem typing in HotSwitches values
Viewing 3 reply threads
    • #171720
      udi9
      I love the new option to type in parameter values in H90 Control 1.4.1, but I’m having a problem when typing in values for HotSwitches.
      It seems that when typing in a value for a HS parameter the new value isn’t saved (changing values with the mouse works fine).
      Maybe someone can try this example and see if it works for them? I might be doing something wrong:
      1. Load a program in H90 Control
      2. Go to the HS1 page
      3. Choose a parameter to change
      4. Type in a new value for this parameter
      5. Go back to the PGM page
      6. Assign HotSwitch 1 to FS1
      7. Save the program
      8. Now press HS1 in Perform Mode and see if the value changes
    • #171732
      Thanks for reporting this. I can reproduce the issue and I’ve made the developers aware of this. I’ll let you know when we have an update that fixes this issue.
    • #171733
      udi9
      Thank you!
      You guys are awesome.
    • #176093
      udi9
      Just wanted to report that I’m still experiencing this issue with version 1.7.1, but now it’s impossible to type in any value at all for HotSwitches.
      After typing in a value and hitting enter, the parameter reverts back to its original value.
