H90 Control Bank program order change
Home Forums Products Stompboxes H90 Control Bank program order change
    • #173065
      cellicello
      I’m a beginner in using the H90.
      Is there a easy way to change the order of program in a playlist?
      Also is there an easy way to transfer program from linear mode to Dual mode.
      I realized that I prefer the dual mode after made a playlist, and as the two mode doesn’t communicate,
      I had to save each program one by one on my computer and then copy the in dual mode.
    • #173070
      joecozzi
      The easiest way to customize a playlist is using the H90 Control application, which allows us to copy, paste, and overwrite Programs to the correct positions. We can also create new lists and move between lists.
      Also is there an easy way to transfer program from linear mode to Dual mode. I realized that I prefer the dual mode after made a playlist, and as the two mode doesn’t communicate,I had to save each program one by one on my computer and then copy the in dual mode.
      There isn’t any easy way to transfer Playlists between Insert and Dual mode, but you used the best alternative.
