Home › Forums › Products › Stompboxes › H90 Control Can’t Connect
- This topic has 6 replies, 4 voices, and was last updated 1 year, 8 months ago by radiation360.
March 31, 2023 at 2:09 pm #170017radiation360Participant
For some reason, my H90 Control no longer connects to the pedal. When USB is connected and I select the device to add from the dropdown, I get a pop-up saying “Error opening midi ports, device may be busy in another application!”
I’m using Windows 11 Home; my H90 is on the latest firmware (v1.3.0) and I’ve just done a full factory reset, but nothing has worked. The only option I have under preferences in Control is related to the knob style. I’m using Control v1.2.2. Anyone experience this before?
March 31, 2023 at 2:18 pm #170019malkyshyParticipant
Are you using the usb cord that was supplied with the unit? My H90 wasnt recognized by H90 control from day one. I tried another usb cord and it works fine ever since.
Hope this helps 🙏🏼
March 31, 2023 at 2:22 pm #170020radiation360Participant
I’ve tried multiple cords in multiple ports. If I unplug it entirely, nothing shows up in the add drop-down all, so as far as I can tell, it’s not an issue with the USB connection itself.
March 31, 2023 at 3:04 pm #170021LorpalParticipant
Are we you also plugged into midi at the same time? I had an issue once – unplugged the din plug and it worked fine. It happened only once and I haven’t been able to replicate it.
March 31, 2023 at 3:15 pm #170022radiation360Participant
Nope – I was hoping to just use USB for MIDI. I’ve unplugged from the USB hub and everything, just plugging straight into my computer, and still nothing. I just have power, usb, and in/out 1&2 for stereo guitar plugged in.
March 31, 2023 at 4:08 pm #170025brockParticipant
Do you have (or had) any other MIDI devices / apps open recently? Windows always had a way of hogging the MIDI ports. There is/was a method for freeing them up at the system level (which I don’t recall offhand).
I recently had a similar kind of issue with Novation Circuit Rhythm. The unit was no longer plugged in, but I believe it was Novation Components still running in the background.
Once I squashed that, H90 Control opened up just fine.
March 31, 2023 at 4:48 pm #170027radiation360Participant
That more or less did the trick – I tried to close the Morningstar software, which crashed Windows, and after a reboot it all worked fine.
