Home › Forums › Products › Stompboxes › H90 Control Instructions?
- This topic has 10 replies, 4 voices, and was last updated 2 years, 5 months ago by
gas hed.
November 13, 2022 at 9:53 pm #166657
I can’t seem to find a download for the H90 Control instructions…is there a how to out there or do I have to figure it out on my own? I’ve got a show on Black Friday and would love to use the H90…can I figure everything out in time???
Before:
After:
November 13, 2022 at 10:15 pm #166658
Hi gas hed, thank you so much for your support of Eventide. Congratulations on your new H90 Harmonizer! Currently, the only documentation available is the quick reference guide that came with our pedal and the official user manual, which you can find here: https://cdn.eventideaudio.com/manuals/h90/1.1.2/index.html
Eventually, we will have documentation for the H90 Control app, but it is in the works, as well as supporting video content. In the meantime, feel free to ask any questions here in this thread and we’ll do our best to answer them. I, myself, am working on a video version of the manual, but that’s still a few weeks out.
November 13, 2022 at 10:33 pm #166659
Thanks for the quick reply joecozzi – I’ve been messing with it for the last hour or so and am getting the hang of it. It is actually a bit more intuitive than the interface for the H9. Wondering if there is a way to manually input the values for different parameters? It’s kind of difficult hitting the nail on the head for the delay times.
November 13, 2022 at 11:02 pm #166663
gas hed … The Quick Knobs on the face of the H90 are very accurate. Since the H90 is connected to the Control App when Control is in use, you can actually dial in Control App parameter values with the H90 Quick Knobs. So I occasionally reach for a Quick Knob when a mouse and the Control App aren’t doing it for me.
November 13, 2022 at 11:11 pm #166665
Yes, I love that H90 Control responds to all front panel pedal controls.
November 13, 2022 at 10:43 pm #166660
Also, a question if you don’t mind…for my routing (4CM), is path A pre and path B post? I simply save this way and A will always be pre, B will always be post?
November 13, 2022 at 10:48 pm #166661
In Dual Mode, the H90 does not make the distinction between which one of the paths is pre or post. It just makes more sense to think it about it that way: A is “pre” and B is “post.” But technically, you can connect either path to pre or post or vice versa.
November 13, 2022 at 11:01 pm #166662
I don’t understand…terminology is getting me a bit lost. Maybe I should ask the question this way. When in Dual Mode – Is the top line path = pre? Is the bottom line path = post?
November 13, 2022 at 11:09 pm #166664
In Dual Mode, the top line corresponds to the signal flow from Inputs 1&2 to Outputs 1&2. The bottom line represents the signal flow from Inputs 3&4 to Output 3&4. Yes, it’s easier to consider the top line as PRE and bottom line as POST.
November 14, 2022 at 4:20 pm #166700
Does the H90 allow you to control amp channels with the Suhr Micromidi without having to use the Morningstar? I see you added that in the after pic. I’m trying to figure out if I need to get a midi controller beyond what the H90 does.
November 15, 2022 at 12:03 pm #166730
I think the answer is yes. The H90 can transmit MIDI messages, so it seems this should work fine.
