H90 Control Latest – H90 Control 1.8.16
Home Forums Products Stompboxes H90 Control Latest – H90 Control 1.8.16
Viewing 0 reply threads
    • #186424
        H90 Control 1.8.16 (Requires H90 firmware 1.9.4+ / dot9 firmware 2.2.7+)
        General
        • Add eyeball button for password visibility on login screen.
        • Allow pasting into login text fields. (Right click on desktop. Double tap on iPad.)
        • Add a prompt to warn users about unsaved changes if they try to load a different program on H90, or a different preset on dot9. This warning can be disabled by clicking the “Don’t ask again?” checkbox, and it can be re-enabled by restoring default settings on the “Settings” page.
        • Center external mapping popup position above/below parameter.
        • Make “Public Beta” firmware and H90 Control update notifications opt-in.
        • (Windows only) Create an uninstaller.
        • (iPad only) Importing/exporting of programs, presets, and program lists.
        H90
        • Increase character limit for program notes and adjust the program overview panel to accommodate longer notes.
        • Fix H9 Preset List import in Dual Mode.
        • Automatically convert routing of imported programs and program lists if they don’t match the current routing mode of the pedal.
          Update “PERFORM” mode external control description (it increments through Perform pages).
        dot9
        • Add support for all dot9 stompboxes (preset management, parameter editing, and firmware updates).
        • Add “OXU” expression mode (requires dot9 firmware 2.2.8+).
    • The topic ‘H90 Control Latest – H90 Control 1.8.16’ is closed to new replies.
