H90 CV Input Range
Home Forums Products Stompboxes H90 CV Input Range
Viewing 4 reply threads
    • #187825
      jimfowler
        What does the H90 do with control voltages over 5V?  I’ll need to build a thing to scale the CV range of my modular (0-10V) but want to be sure I won’t damage anything if the 5V upper range limit is exceeded.
        Thanks.
        – Jim
      • #187834
        joecozzi
          For voltages over 5, the H90 will just clip to 5V. Up to 12V shouldn’t damage anything, but I would not suggest you go past that (especially if it might be sustained).
        • #187838
          jimfowler
            thanks.  that was my assumption but wanted to clarify.
          • #187856
            AnikaLaughlin
              @ Block Blast What does the H90 do with control voltages over 5V? I’ll need to build a thing to scale the CV range of my modular (0-10V) but want to be sure I won’t damage anything if the 5V upper range limit is exceeded.
              Thanks.
              – Jim
              I think you could use a voltage divider or a protection circuit to limit the input voltage to around 0-5V before feeding it to the H90. Could that be correct?
            • #187869
              jimfowler
                Since the H90 provides over-voltage protection I will indeed build a simple divider to scale the CV input by 50%.  None of the devices in my modular system provide any voltages over 10V.
